Maybe there are differences between Euro and Oz ?
Meah, who cares, bottom line is block the suckers anyway
Helpful read..
Guys,
I have read this thread from start to finish.
loads of information.
here are my thoughts/ questions.
I have a 2012 CRD
I will fit an EGR blocking plate
Hole or no hole?
I have a scangauge 2
I see the plates available on line have about a 10mm hole, this seems quite large, I know its there to satisfy the ECU.
but wont it still allow a fair amount of crap through?
partially blocked, Hmmm.... interesting concept. will fill up with gunk over a longer period of time......
has anyone tried a smaller hole?
it appears from information in this thread that if you don't have a hole it just throws a code P0401 (no big deal I read)
I may do the experiment myself, no hole, 3mm hole, 5mm hole etc.
any feedback or thought would be appreciated.
IMO. If your going to use a plate with the hole, don't bother. Your still letting through the nasties, it just takes longer...
Hodges CRD is fully blocked, he only get the error on his scan gauge and don't even bother with it.
Cheers.
Mark.
Edit : why is your name familiar?
X2 ^^^^^ (cept for the name bit, I'm sure we've never met)
As Mudski said. Mine is a full blank. I get the p0401 code most of the time. But I don't notice it because it hardly ever triggers an engine light. Engine light comes on maybe once a month for some reason and when I reset the code, it goes away.
Even if the code is throw it won't directly impact any performance.
Mark,
because I sent you a PM a while back about Dawes, I still cant decide if its worth it on the CRD.
is there value in adding a Dawes on this model?
after trawling through the forums I see that some tend to believe that the late model CRD boost limits on its own quite well.
not sure I fully understand the finer points of the dawes yet, the jury is still out.
I like to fully understand something before I commit,
Cheers.
Liam
I have a 2012 as well and would like to know if going the way of Dawes and needle valve is useful or not.
The CRD's don't "need" the dawes and needle valve. This is fact. But adding these valves impact greatly on better engine performance. This is fact also. I've fitted quite a few to the CRD's to see the difference myself. The CRD's do handle the boost a hell of a lot better than the Di's do, but like anything, theres always room for improvement. What I don't agree on is the comment I keep seeing via messages to me here and my store that the needle valve is a waste on the CRD. Pure bollocks. Lol. Why only take away half of the ECU's control over boost? Take the whole bloody lot I say. Then you have the final say in how the car runs.
If your going to spend the coin on your ride with bigger pipes, chips etc. Why wouldn't you instal these valves? Your only going to make the car go better.
