Why not just run an external cooler? Saves you stuffing about and you could get some rubber line and a cooler for $30-40
Why do you keep ringing Patrolapart if you never get good service?
Shut up thats why!!!!!!!!!!!!!!!!!!!!!!!!!!
Yes Matty I was looking at it and I think I could use my efi cooler and make that work... I was staying out of the engine bay today so did not dig deep into working out what would work.
As its not on the pressure side it matters not that I use lots of hose?
No it doesnt matter although its better to keep hose to a minimum. A small aftermarket one mounted closer to the drivers side so then you can use about a metre of hose just to get out to the cooler. Just remember the more hose you use the more likely it can rub so tie it well or even use a sleeve on some sort.
Try Readies, I can pick parts up from them and get them to you. I have always found them reasonable. Clint who will probably answer the phone owns the place and is more than helpful.
http://www.readies4x4.com.au/
Cannot for the life of me get this clutch fork back together... I can't believe this is what's stopping me from finishing the conversion. Just about ready to bin the whole lot.
Also try Allied in Dandenong South, they have been great when I've used em, they're just off eastlink, or 10mins from my house.
