the reluctor is for the DS-4
ROFL... excuse the flash back... just recalling the number of dudes I used to get into 'animated technical discussions' with on this subject and how to use a TC Lock Up Switch mod.
Having said that I couldn't find any Tranny Joint over here who would touch my 4L85 / GM Supermatic Controller combo.
I thought the Commodore specialists would have no issues but they wouldn't have a bar of it.
Bit the bullet and did the Lock Up programming myself.
Took a lot of trial and error but got it so I was happy in the end.
Main issue I had was setting the maps so that the Gear change points and TC Lock and Unlock points were suitable.
Top gear was easy but the intermediate gears got a tad messy 'cause the engine is such a low and slow revver
OK, waiting to pay the invoice from Leroy Diesel for the DS-2 set. $275 USD plus $40USD delivery
@MB, you might want to take a look at this pump setup from Summit Racing. It uses a machined impeller with a closer fit inside the housing to achieved higher flow rates - I think you can also buy the impeller by itself and fit it to the water pump. I am pretty sure the vee belt runs cw?
https://www.summitracing.com/oh/part...1880/overview/
@poindexter, Ralph, where did you buy the fluid damper from? I have trawled back thru the posts but could not find it - thinking since I have to pull the balancer off to install the timing gears I may as well upgrade at the same time when everything is apart.
thanks
Summit racing in the USA
https://www.summitracing.com/int/sea...d=6.5%20diesel
Finally got the part number for the high output water pump from BD. Its an AC Delco 251603. It appears to be the same capacity as the original high output pump, but has a screw on fan assy instead of a bolt on. Its serpentine belt driven also.
Ordered the fluid damper this morning. Ended up going with Leroy Diesels instead of Summit. Summit made a meal of the enquiry and their arrogance lost them the sale. Could not get a delivery cost out of them, their auto check-out system contradicted the sales guys and then I had to resubmit a product enquiry after sending them a request to delete the original - NOPE, why should I have to do the work to fix your screw-up. Pack of monkeys.
One email to Leroy Diesel, invoice received, paid 5 minutes later, 15 minutes later had tracking number, now thats service.
These were waiting for me when I got home for R&R today, timing gear set and fluid damper. Heading over to the land of Yarra Glen on Monday to pick up my safely stored Supercharger kit from Mr @MB and @AB - thanks guys. Its real when the bits are in your hands - now just have to find the time to sort it out.Attachment 78230Attachment 78231Attachment 78230Attachment 78231
Most welcome mate and welcome back home!
It is most definitely safely stored, on top of my now 6.5SC [emoji106][emoji106]
Getting real now, whole kit in my hands.Attachment 78258Attachment 78259Attachment 78260Attachment 78261Attachment 78262
The photo of the front of the engine is from the trial fit due to wider pulleys being installed
Guys, radiator was ordered with bungs for upper and lower temp sensors plus a redarc low coolant sensor. True to form, the Redarc bung was not added. Can you advise how far down from the top of the radiator it should sensibly sit - will have to get this welded in before I start.Attachment 78263
Dare I make the reckless statement that I have finished buying stuff for the s/c conversion???? Just pulled the trigger on a billet aluminium harmonic balancer pulley in 8 rib config from Leroy diesels. $250USD plus freight of $75USD. This will replace the unit I had supplied by BD which is a heavy steel and rubber unit - prone to delamination over time, and will reduce weight by 3kg approx.
Surely you can squeeze aboard an N2O bottle or two @PeeBee mate, don’t be a Quitter [emoji106][emoji106]
I thought the pulley set you got from Bullit had the 8 rib balancer pulley.
My understanding is the balancer is the bit with the rubber but not the actual pulley, is that not the case then?
Bullet only supplied the s/c nose pulley, all other pulleys via BD.
There are two parts with rubber,the factory balancer and the factory pulley. I have replaced the balancer with the fluid damper and now replaced the 8 rib pulley with the aluminium billet pulley. yes, its confusing, and surprising, but until you actually get the parts into your hands, you never know what you are getting. I cannot check whats on the vehicle without pulling it apart, so am going with the two parts upgraded without the rubber.
Where are you up to with your build? Going OK? I sent you a PM - did you see it?
The shop manual that I have shows no rubber on the crank pulley
Just saw the PM.
OK, time for an update :
It has been 5 months now and other than the engine removal, nothing has happened.
I'm at a loss as to what carrot to dangle under the noses of these guys, but money is not one of them.
To be fair, he has struggled with workload, but as I have said many times, that's not my problem.
He has a lot of work and is getting stuff done, just not my stuff.
Got assurances that my "project" will get the attention that it deserves after easter. If it does not, I'll be looking else where.
At the moment I have not been pushing too hard as I've just been through two major renovations at the house, but that has all finished now.
So, I'll give you guys an update 4th May, and please feel free to pester me.
that is allll
Just saw this entry in the shop manual:
Procedures for Destruction of Equipment to Prevent Enemy Use . . . . . . . . . . . . . . . . . . . TM 750-244-6
Interesting, I am now wondering if BD have taken the harmonic balancer pulley and machined the outside off to produce the 8 rib pulley - as it looks suspiciously like that pulley come to think of it. Anyway, I have the replacement on the way so don't have to think about it.
Hi Guys
I've been reading through the thread for a few days now trying to soak up as much info as I can. I'm looking at buying an all ready converted GU with the turboed 6.5 + 4L85E. Apart from overheating issues, is there anything in particular that I need to be looking for with these engines? Apparently the one that I am looking at has recently had the injectors replaced. Is that something of a concern?
Adam
If it is already converted and the owner has had it for a while, I would think the majority of niggly issues associated with the conversion would be sorted by now. I have a GQ manual so cant comment on the auto. Injectors could simply be age, or crappy fuel or tune related perhaps - is this a private sale or thru brunswick? Can you get a service history verified?
Do you know if the motor was new or a s/h or BD reco engine? If a s/h engine could just be old injectors needing to be replaced.
Thanks PeeBee
It's a private sale, and I haven't actually been to see the car in person yet (hopefully next weekend). If it were through BD or a dealer I guess I'd feel a little less nervous as there would be some form of warranty. I wonder if I called BD with the VIN or engine number if they would have the details of what was done at the time of the conversion?
Update as promised, although a day late.
Technically, nothing has been done, however, the workshop is in the progress of being reorged for the work.
I'll be convinced when I see progress, or I'll be looking elsewhere...
that is all.
Update time.
It has started,
Engine out, engine bay being prepped, firewall is having shiny heat shield/sound deadened material fitted.
Hydroboost brake booster is going in.
Looking forward for trial fitment of engine and gearbox as I want to see the oilpan to diff clearance.
The 6.5 blocks lack a trans mounting bolt at the 12 o'clock position, I'll be putting one on with a "beaming bracket" that will bolt on and pick up the mounting hole on the trans.
I'll post pics when I checkout progress this week.
that is all
Hi all, currently puting together a turbo kit for my gu 6.5 and looking for a decent large top mount intercooler. BD ones are too small imo and the cross country set ups are $2500. Any recomendations?
Jump onto the Aussie P400 Optimiser facebook page - quite a few guys on there that have done the yards you will benefit from.
Update time:
Engine is together after the gear drive and fluid damper update.
Trans is trial fitted to engine and "beaming bracket" design has commenced.
Existing engine mounts removed from chassis, and new brackets are next to go on.
I'm keen to see the engine in "the hole" to assess the exhaust and fan to radiator clearances.
Attachment 78934
Alright, time for an update:
The engine has been trial fitted into the engine bay and positioned as per the Marks adaptors bits.
I'm not happy with the location, so, the position will be revised approx 35 to 50mm rearwards to allow additional clearance to the radiator.
From my understanding, this is a common problem.
There appears to be plenty of room to move at the rear of the engine, with the drivers side cylinder head to dash panel being 70ish mm gap at the moment.
Interestingly the upper pulley seems rather high.....
I'll be looking into the oilpan to front diff clearance to see if I can lower the motor.
that is all.
see pics
Attachment 79064Attachment 79067Attachment 79066Attachment 79065
Beautiful Stuff Ralph mate!
Huge work both your good self and PeeBee are putting in, Legendary Blokes!
Please do massively consider as you’re already above onto front diff clearance to P400 sumps mate.
Higher power, hotter oil, originally were designed about 3.0L too less IMHO nuffy opinion mate!
Highway Only Weapon Tugs are for Cheators [emoji106][emoji106]
