Bit of stress actually
There was a young Asian man trying to inflate his tyre but it was blown out and he thought the pump was fubar
Sent from the crapper while on tappa
I'm guessing from your description he looked like the fellow. Attachment 26269
And his dog.
Attachment 26270
Installed the UHF & RAM mounts for the phone & iPad
“The best way to cheer yourself is to cheer somebody else up.” - Albert Einstein
Can we get the pic of the bull on roids please.
I checked the water again, low, but I haven't checked for
a while I must admit, will keep an eye on it when I go away
Then I'll suss out larger radiators,
@ Mego when you work out dude use the wet flannel
uses ALL muscle groups, LOL
Installed my map sensor onto the firewall for my boost gauge, and ran some wire in for it, Now just gotta wait for my pod to arrive to install gauge.
Also used some sticky feet to tie off my mic as the lead keeps dropping down and brushing my leg, so now its all good and up high out of the way :)
Took time out and Rewired and tidied up the wiring to suit the camper, what a dodgy the previous owner did, bare wires, broken wires, broken connectors. Any wonder the lights didn't work properly towing the jet ski. All sorted now, clean and tidy and looks the part with the new metal plugs.
TAPPN OUT
Finally put + & - bus bars behind the back seats, in front of my drawer system.
It will allow direct 12v from the aux battery for anther 5 items or so in the back, including the water pump I got for free!!
Also fitted a screw in power socket so the Engel power cord now screws in. As apposed to using the 'cigarette' lighter plug and have it rattle loose...again.
SO...I finally got my 40L Engel fridge connected to the aux battery, so I can take the keys out and lock the car, instead of having the accessories on.
Only took my 1 1/2 years.
33x12.5 bighorns on 15x8s and a 3" efs lift wooo
Tappin trolls
Brendan
Photos!!!!!!!!!
I put my muddies on today, ready for some action this weekend!
Glued in my housings for my bullbar indicators tonight, also spliced into the loom to give me power for em, now tomorrow all I need to do is screw the lights in and wire them up!
Drove around Pemberton and took the family to Big Brook Dam
Sent from my GT-I9305 using Tapatalk 2
Strengthened my rear lower control arms with angle iron. Saved my self $300.
http://imageshack.us/a/img819/1619/5...3554859988.jpg
took my front bar off and driving lights and aerial take it to the panel shop tommorrow then when its done its off to town & country for the new bar and winch install
Testing the positioning, need to do some more permanent wiring as well.
Attachment 26692
Helped a mate adjust the valve clearances. It was getting a bit noisy but now it's purring like a kitten and a little more mid range power.
Very happy with the results and I learnt how to do something new:-)
FanTapstic!
Wow.... Must be the week for it .... Had my valve clearances done this week plus injectors and new viscous fan, getting it tuned on the dyno this week....
Haven't seen the car yet as I am at work but they reckon it is a different car, I didn't even notice the injectors needed doing, they noticed it on the dyno two weeks ago when they did the uni chip!
My TB42 is fairly clapped out with 430,000 on the clock but I was very surprised to feel the difference in power from just doing the valves, so I imagine yours with new injectors and a tune on top will be a different car:-)
FanTapstic!
Had new brake rotors fitted all round. Needs a balance now
Replace the GU drivers side door window bailey channel. Paid around $15 for it from Clarke Rubber rather than the $190 Ni$$an wanted. Not exactly right but you can't really tell as I still kept the top moulded section. I also adjusted the door so it closed properly. Needs a new hinge but thats a job for later.
Added more bling
Attachment 26893
Stuck one of these knock down brackets in coz the garage is too low or is it that the antenna is too high ? :)
http://telcoantennas.com.au/site/bul...k-down-bracket
Made up a Brake bias bracket for my new 5" flexy kit. Saved myself $30 :).
http://img703.imageshack.us/img703/4530/gopr0015y.jpg
Uploaded with ImageShack.us
Had a wheel balance etc done, ordered a new Oztrail awning tent. Just need time to do the eagle eye LEDs
Never underestimate the power of the Tap.
I was drifting on the wet roads, holding a controlled drift around a roundabout, scary but fun.
Cracked the brake light cover jack knifing the box trailer into the car port ..........ooopppppssssssssss :(
Filled it with water in a bog hole!
Tip tip tip......tap tap tap....
Oww noooo
Owner of
Westy's Accessories
Removed the wire winch cable & roller fairlead & fitted the Dyneema & alloy hause. Knocked off just over 13 kg & feel a lot safer 'playing' with the winch now.
I reckon the wire cable must've been pretty new when I bought the vehicle, it was in very good condition. I'd expected it to be curl up & become unmanageable when laid out on he ground, but it just laid flat behaved itself. :)
When things were happening slower as I got closer to the tree I was winching the vehicle to, I thought briefly that the battery might be going flat, until I remembered that pulling power reduces with each layer on the winch. Phew!
Cuppa
Trust you did the first two rows tight then from side to side fast for the rope p
As for your old winch cable take it to a cable shop and get eyelets fitted both ends
cost is very minimal and makes a great extension cable if needed
Went for a drive to Grovedale Geelong to pick up a redgum slab.
Having just filled it will now work out my fuel figures, its a 100kph
both ways most via fwy.
Put a new sway bar in after I broke the old one .... Apparently the missus didn't feel safe with the body roll
Admired it as i drove off to work:rolleyes: Weekend work should be banned:)
Sent from my GT-S7500T using Tapatalk 2
