Shes pretty much finished... just need to make up 4 inch intake frm throttlebody back to the airbox... then its off to get exhaust and engineering done hopefully end of the week...
Sent from my SM-N915G using Tapatalk
Shit yea. What a build..
Will post up a vid soon..
wow... read this whole thread, as i was reading it became suspenseful and all i wanted was a vid of it in action and then i arrive here lol.
what a bummer... ah well... subscribed! :P
Haha il upload a vid soon.. hopefully can get my zaust done tomorow.. then i can finally drive it.. im pretty tempted to have a blast arnd the block but im still only running just open headers.. so shes loud as...
Did a bit this arvo.. Mockd up my air intake.. finally got all my electrics sorted.. had a problem with my fuel pump blowing fuses but thats all sorted nw.. was basically earthing out my bulkhead fitting frm the pump.. ie it was making contact with the body when i bolted the tank back up in place.. causing it to arc out.. so i fliped the bulkhead fitting.. had the excess thread going into the tank and the head of the bolt on the top side of the tank... there were like 3 or 4 wires i had to tap into to get everything working mickey mouse.. tacho for dash.. power to ecu and a switch and light setup to manually overide ecu to turn thermo fans on and off for river crossings etc.. was a bit tricky as ecu controls when thermos come on and off... anyways everythings working as per normal on the dash which im pretty happy with.. temp.. oil.. speedo.. tach etc..
Did a final solder of wires and taped up loom... bolted up ecu and fly by wire module up under dash.. happy days..
http://www.nissanpatrol.com.au/forum...015/11/129.jpg
http://www.nissanpatrol.com.au/forum...015/11/130.jpg
http://www.nissanpatrol.com.au/forum...015/11/131.jpg
http://www.nissanpatrol.com.au/forum...015/11/132.jpg
http://www.nissanpatrol.com.au/forum...015/11/133.jpg
http://www.nissanpatrol.com.au/forum...015/11/134.jpg
http://www.nissanpatrol.com.au/forum...015/11/135.jpg
Ok for some reason it wont let me post or upload a vid.. anyone nw hw?
https://youtu.be/K88LhZ6GbYA
Yo buddy what have you done with the ZD30??
some late model flares would look the part, check Hodges ride
plus he's making it unique so it will stand out from others be it suttle.
Sold the dirty zd30 for 1200..
Cool ,Ive decided to make up a 8mm copper pipe that goes around the back of the motor.
Better than the OE pipe thats corroded.
Lovn my patrol nw.. the look on peoples faces when u drop it dwn a gear.. priceless
Youve got your ride lookin and sounding great Mullet hunter! What was the final cost?
Ive sort of lost track but ive got a bag full of receits.. all i knw is i saved about 7k doing it myself.. i budgeted 10k.. i think i might had went maybe a grand or 2 over that... but ye il be posting up a list of all parts used and prices and part numbers...
http://www.nissanpatrol.com.au/forum...015/11/160.jpg
http://www.nissanpatrol.com.au/forum...015/11/161.jpg
Need to get some more vids of it.. but pretty happy with hw its running.. 300kw mafless tune so it would have a easy 300 ponies at the wheels..
Just waiting for my mod letter to come back frm w.a transport... been 9 weeks and still waiting.. once i get that i take it over the pitts and shes all legal..
Just wondering where u ran tachometer wire from LS computer. Strait to tachometer or if anyone can help. Put ls2 into zd30 and not sure where to run it
Great job looks sweet👍
the LS looks at home in GU engine bay.. great build mate.
