Hi Swampy.
The double row Aurora's are a 3w LED. The single row Aurora's are a 5w LED.
By the way, that price includes shipping.
Thanks,
Paul
Hi Swampy.
Thanks,
Paul
Hi Megomonster.
The 3w double row Aurora's have 14400 lumens and the 5w single row Aurora's have 19600 lumens.
So obviously a difference however the double rows at $600 are amazing value.
Cheers,
Paul
Thanks for the reply, are you able to get the 5 watt double row? And if so how much can you do them for? Thanks
Just arrived new range of LED light bars.
LIGHT BAR 14" 60 WATT 6 X 10 WATT CREE LED'S COMBO BEAM $135
A high light output Light Bar at an affordable price
10W X 6 Cree LEDs 5400lm
Colour Temperature 6000-6500K
Working Voltage DC 9V-32VDC
Current Draw 4.26 amps at 12V. 2.2 amps at 24V
Operating Temperature minus 30 to + 50 Degrees C.
Waterproof grade IP67
Body material : Diecast Aluminium
Lens material : PC (polycarbonate)
Beam angle 8 (Spot) and 120 degree (Flood) = Combination
LED life 30,000 + Hr
Totally electrically Protected against RFI/EMC interference (Radio Noise)
Bolts in Stainless Steel
Double Insulated Cable
These produce a massive amount of light and are virtually indestructible.
Can be mounted in a multitude of positions with brackets supplied.
LIGHT BAR 22" 100 WATT 10 X 10 WATT CREE CHIPS COMBO BEAM $175
10W X 10 Cree LEDs 9000lm
Current Draw 7.1 amps at 12V. 3.6 amps at 24V
LIGHT BAR 30" 140 WATT 14 X 10 WATT CREE CHIPS COMBO BEAM $349
10W X 14 Cree LEDs 12600lm
Current Draw 9.94 amps at 12V. 4.98 amps at 24V
LIGHT BAR 42" 200 WATT 20 X 10 WATT CREE CHIPS COMBO BEAM $435
10W X 20 Cree LEDs 18000lm
Current Draw 14.2 amps at 12V. 7.1 amps at 24V
LIGHT BAR 50" 240 WATT 24 X 10 WATT CREE CHIPS COMBO BEAM $499
10W X 24 Cree LEDs 22000lm
Current Draw 17 amps at 12V. 8.5 amps at 24V
Contact me to place an order and I will over ride the price on our website and also send your order out freight free.
Hi,
What kind of housing are these in?I have seen a few in mining applications up to 7 inch and they weigh more than my 22inch 5w as they have a large heat sink and housing. These dont look any where near the size, how well do they dissipate the heat.
Ben
Hi Ben and thanks for your enquiry.
The housing is made of diecast aluminium. There is a picture of the dimensions of these lights on our website with each 10w lightbar however the body is 76.39mm high and 86.5mm deep. The pictures do not give a good indication of the size of these lights.
They are not small like a typical 5w lightbar housing. There are some small 10w lightbars available however our manufacturer is staying away from this design at the moment after testing some and the housing becoming very hot. LED's will last a very long time providing they are kept cool and the heat generated is dissipated appropriately hence the bigger housing.
$$ for lumen output they are great.
Cheers,
Paul
Just ordered a set from Paul for my Prado (don't hurt me). 2 x 10" & 1 x 20" both single row Aurora 5w led bars. Paul was extremely helpful and answered many of my questions promptly.
Will post a some photos of the setup once it's all in!
Hi everyone, Paul has now become a basic vendor sponsor so please welcome him to the forum and best of luck with your products mate!
Welcome Paul, good to see you jump on board as a paid vendor :)
Thanks guys.
If there is anything at all I can help anyone with or answer any questions let me know. Always happy to help.
Thanks again,
Paul
Good to see mate
Owner of
Westy's Accessories
Do you sell Lights?
I sell tyres Darren..
x6 37" BFG Krawlers to be exact.
Ohh, and I sell lights every now and then :wink:
Hi Paul,
I'm toying with fitting some of the LED light strips on the interior of my 09 GU right side barn door and have seen a kit for sale on EBay which has everything you need. Do you sell these as well or do you sell/recommend the strips and other necessary parts separately?
Cheers.
Thanks for your enquiry.
We do not sell a kit which includes everything with our light strips. The main reason for this is there are many ways in which lights can be connected and everybody has a different idea/reason as to how they want things done.
We do have a wiring harness that we sell with some of our lightbars which you could use, however some small amount of modification may be required depending on your application.
There are two harnesses available. One with switch and fuse for $17 and the other with switch, fuse and relay for $24 (normally $29).
We also have an LED strip available that can be cut every three LED's allowing you to custom make a length. They are not on our website at the moment but I can do these for between $13 to $19. Price is dependant on how many LED's you want per length.
If you have any further questions let me know.
Cheers,
Paul
Dropped in to see Paul today after catching up with some clients in Geelong and picked up a ripper 35W LED work lamp for a great price while I was there. Can't wait to mount it up....
Thanks Paul. I'll be back!
Cheers,
Drew.
Was going to call you then I checked my wallet.. Wife stole the dam cc again..
Bugger mate.
Whenever you're ready give me a call. Hope everything's going well for you!
While stocks last..
10" flood or spot beam light bar $82 delivered!
Specs and pictures in below link.
http://www.ledlightco.com.au/light-b...ps-flood-beam/
We have had a new shipment arrive today. First new product is an 18w mini light bar. Forum price is $23.75 including free shipping!
http://i35.photobucket.com/albums/d1...ps3f5c9cbd.jpg
Hi Kallen.
The 18w lights are 160mm long 60mm deep and 45mm high.
Cheers,
Paul
You mean like this...
Second new product is a 60w LED driving light. Forum price is $210 a pair including free shipping!
http://i35.photobucket.com/albums/d1...ps3ee14781.jpg
Yes, they are 7" and around 5100 lumens. We have spot and combination available. The spots unlike a lot of other LED lights are a VERY tight spot.
PM sent to you mate
