Yes. From my research when I owned the 3ltr, the stock turbo is quite capable of anywhere up to 25psi. Anything above this your running a high risk of damage to the turbo.
This motor is in a 2002 4x4 Elgrand. Had all the inlet pipework and intercooler off on monday and cleaned it out.
Nothing on the intercooler. Only has the MAF sensor between the air filter and turbo.
Just had flick through of workshop manual, engine control section. No mention of any MAP or pressure related sensor. Also NDS1 doesn't show anything either.
Sent from my SM-T355Y using Tapatalk
I thought the MAP sensor and shorter dipstick ( more oil in sump ) were nissan's initial response to the grenading. BTW which vehicle out here had the ZD30 first, the patrol or the navarra?
The Elgrand is a bit of a mix and match. Engine from patrol/navarra, drivetrain from terrano/pathfinder.
