pearcey
G`day Guys
Bleeding the system with a new or recon master is a simple job but needs two people.
One on the pedal and one at the wheels. doesn`t really matter which where you start , but first bleed the master. Fill the master and REPLACE the cap,person on the pedal pushes pedal to floor (do not bang the pedal down, just push it down easy) only once, holding pedal down. person on the spanners cracks the pipes at the master, once air and fluid stop flowing retighten tube nuts, now person on the pedal releases pedal SLOWLY over a time of around 5 seconds. DO NOT pump.Repeat until all air is expelled and only fluid comes out.WARNING the fluid does squirt all over the place so a cover of rag and plenty of water around is necessary. IF the fluid gets on paint work wash it off strait away with flowing water.. OK master bleed now to the wheels, dosen`t matter where you start but farthest away is not a bad place to start. Person on pedal pushes pedal down and holds it down, spanner man opens bleeder and waits until air and fluid stops flowing, shut bleeder then person on pedal, SLOWLY "5 seconds "releases pedal,then waits another 10 second before pushing pedal to floor again. Repeat until only fluid comes out at the bleeder. Repeat process at each wheel and then you should have a good hard pedal.DO NOT bleed brakes with the engine running. Now with a reasonably amont of pressure on the pedal start the motor and the pedal should drop a small distance, this indicates that the booster is working.
If there is a bleeder on the load sensing valve bleed this before doing the rears.
OK reasons for NOT pumping pedal. the seals in the master are designed to collapse when the pedal is released and any air in the reservoir side of the piston will be dragged into the pressure side, but releasing it slowly gives the reservoir side time to recover, once the system is air free it can operate at any speed. The same problem happens with drum brake system where when bleeding, a quick release of the pedal can and will draw air into the wheel cyls especially if they are old. Another thing I do is to clamp of all the hoses apart from the wheel being bled, this stop back and forth movement of fluid apart from the wheel being worked on. WARNING DO NOT CLAMP BRAIDED HOSES.
Hope this is of some help.
