Winnie,
I have got exploded diagrams of the 8274 and a few other docs if you want them? (in PDF format)
Rob
Winnie,
Rob
All good mate, I've got those off the Warn website.
Cool. Should post em up here.
Yeah I will do that when I get home.
Ah yes i think that is a good idea! ! !
I used those you tube videos when i rebuilt mine they were a great great help. Think i used the dremel and some emery paper to finish the aluminum. It's how the new high mounts are finished, looks good i reckon.
Think i will pull mine out shortly and give it a few tweaks and some lovn'. . .
What are you planning on doing with yours now?
The end cap I scored has been modified to take a bearing instead of the nylon bush, should make freespool a little easier.
I'll have all the bits on Monday ready to pull apart and take to the sandblasters. I reckon I'll have a fun time pulling apart the brake system on this bottom end I have.
Not too much. . . Somehow popped out the seal on the brake assembly will have to look at that. Might pull it apart and tap a filler & drain plug, new freespool lever and new rope. . . Also need to finish off the wiring and put some buttons on the bar and an isolator. . . Actually that is a few things.!!
Yep The brake asembly was a royal PITA to get off on mine took a fair bit of squirting & whackn. Good luck!!
