Will be fitting second battery tray to mine shortly
bought a new windscreen washer bottle and motors as mine has disintegrated, so should arrive before next weekend, finally got fed up after 3 years of squirting a water bottle out of the window in order to clean the windscreen
Thanks Cam.
Mine on the other hand came with the two points, four 3/4 bolts with foprives ur smaller bolts, and the two captives with the wire..
@ Trekster how bad is it, totalled, I think RACV down here say car/4x4 is UN RW with hail marks all over it.
Personally I cant see why, hope its repairable at least
Did more to my custom "bar by growler" by triangulating for strength.
Aaaannnnnd put some new stickers On Cheers Lucas
Should strengthen it some what ,,,,,,,,,,,,,are the ends enclosed???
HAhahAHHAHAHAHAHA yup sounds good, but can you keep it clean hahahahahaa
Completely gutted the rear end, cleaned up mud and crap stuck between the chassis and rear bumper area. Probably about 10kg of s*** came out.
Tidied up tow bar cabling with new plug etc... and install the tow bar while I was at it !!! I also took photos of step by step tow bar install, and I'm considering a small write up on it that may help some in the future, as I was in the same boat a while back!
Now kickin' back with a few nice cold stubbies!
http://imageshack.us/a/img820/803/4zmg.jpg
