Ring me you bloody goose.
Paul. Yr phone goes straight to message bank. R u gossiping or is it my phone.
I've made a decision:-) I'll use what I have and shut my mouth until it'fixed
mate I know how frustrating it can be. My touch pad and keyboard lock up all the time on my lappy, I can't really be bothered trying 2 fix it anymore, It freezes..........I restart it..............It freezes...........I restart it.............its a never ended cycle :)
Hi guys, So what determines your download speed and can i speed it up, very frustrating trying to download files ?????
Go to http://www.speedtest.net/ and press "begin test" (recommended server) wait for the test to end and tell us what your download speed is...you can post it up if click on "share results" and copy & paste the URL from the "forums" section. This is mine...
http://www.nissanpatrol.com.au/forum.../2011/12/2.png
OK SCADA, done cant share, note that bright.....hahaha
Readings:
Download speed..0.32mb/s
Upload speed..0.54mb/s
ping..94ms
Grade...D
isp optus internet
server..Canberra (-300ms)
very very poor...might be time to update
by the way.....just took an hour to download 22mb file.....C%*#
Todd's right on the money here Pete, get rid of that crappy internet you have & get rid of your problems at the same time mate.
Hi Toddrhind,
Sounds like the operating system is locking up or at least the HDD may be having trouble.
I'm assuming you are running Windows XP or Win7? If so, run the following instructions:
1. Click on START and choose RUN
2. Type "CMD" (without the quotation marks) and press the enter key. This will open the command prompt.
3. At the flashing cursor, type "CHKDSK /R" (without the quotation marks) and press the enter key. It will say :
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N)
4. Press the "Y" key and then press the enter key.
5. Now restart the computer.
Check Disk will run when Windows restarts and will run 5 different checks on the hard drive. Here is a link to the explanation of what this program does http://support.microsoft.com/kb/187941
In a nutshell, chkdsk /r will check the file system, partition tables, Operating system files etc. If it finds any inconsistencies and can repir them, it will.
This program can take a while to run depending on the size of the hard drive and what problems it encounters.
Once the program finishes the computer will continue to boot to Windows and you can log in as normal.
Straight after CHKDSK is completed, run "Disk Defragmenter" to tidy up the files on the HDD.
This is the first step in troubleshooting this type of system failure.
Let me know how you go.
Cheers,
Rob
Thanks for the advice guys, have phone line but young fella runs off that and it's upstairs, might look into running off his net with USB connection or upgrade mine.
Hi Todd,
Check the Event log under Application. Look for an event called "Winlogon" at the time the computer logged on after CHKDSK finished. This will give you a report on what it found and fixed.
Your specifically looking for "Bad Sectors" or "Bad Clusters" this means you have a faulty HDD and it should be replaced.
Cheers,
Rob
I stole the missus's lappy, that's why I'm back to DX grunt. Mine goes back to the shop tomorrow for, hopefully, warranty repairs. lol
I miss gruntlet. lol
It never ceases to amaze me the wealth of all kinds of knowledge on here...lol
You can schedule chkdsk on win7/64bit in a normal windows environment by right clicking on the drive in question going to properties, once in properties select the tools tab then click on the check now tab in the check error box (the top one) check both options boxes then press start. A message will appear asking you to schedule for next startup which you do & your done.
Chkdsk will take a while to complete its task & should reboot the system automatically when its done. If not it will prompt you ro reboot the system manually.
