Haha ye...
Sent from my SM-N915G using Tapatalk
http://www.nissanpatrol.com.au/forum...015/10/268.jpg
Had a quick 40 mins outside before wifey cooked dinner... managed to make up couply brackets and fit my thermos in place...
http://www.nissanpatrol.com.au/forum...015/10/269.jpg
http://www.nissanpatrol.com.au/forum...015/10/270.jpg
Fittd new clutch master n braided line dwn to bellhousing..
http://www.nissanpatrol.com.au/forum...015/10/271.jpg
http://www.nissanpatrol.com.au/forum...015/10/290.jpg
Lazy heat shield to protect brake and fuel lines frm headers... should keep everyone happy..
http://www.nissanpatrol.com.au/forum...015/10/291.jpg
Made up my flash boy racer power steering lines...
http://www.nissanpatrol.com.au/forum...015/10/292.jpg
Fuel line from regulator to fuel rail...
Hey mate, have you got any photos of what you did to the fuel and brake lines. Having the same dramas with exhaust on the windsor conversion.
They need to be moved frm the side of the chassis rail to the top side.. then the heat shield installd to cover them...
Have only done brake and fuel lines.. still need to do diff/gearbox breathers on the passenger side... then engine bay should be pretty close to dropn in the ls...
what size exhaust you running loud or not so loud LOL
Does it require custom headers?
Was going to run and single 3 inch but im thinking twin 2 and a half inch... using advanced headers..
I heard a Y62 patrol the other day with a twin system
very loud,,,,,,, all I could say was WOW.
If you can get a twin system to fit that would be awesome
better for a V8 too IMO one pipe per bank
Looks like i need to upgrade my airbox too.. going to get one frm fatz fabrication... same as this pic...
http://www.nissanpatrol.com.au/forum...015/10/316.jpg
As long as the heat Shield works..
Why doesn't the stock zd box fit??
Does it differ much from the td vertical box?
The zd box fits... but its highly restrictive with the ls.. they like to breathe..
http://www.nissanpatrol.com.au/forum...015/10/317.jpg
http://www.nissanpatrol.com.au/forum...015/10/318.jpg
Sime lazy sliders i was knocking up for the pooey and the bro's prado..
http://www.nissanpatrol.com.au/forum...015/10/320.jpg
This brake line needs to be moved as it will faul the aircon...
http://www.nissanpatrol.com.au/forum...015/10/321.jpg
Like so...
Do you have any pics of the fuel lines? Did you just bend them out or cut and join?
Ye you just move them from the side of the chassis rail to the top side... the heat shield will will cover everything ontop of the chassis rail... dont cut them... im gona use speedflow fittings that go streight frm the hard lines to dash 6 fittings.. and frm there to my regulator/filter then onto my fuel rail...
http://www.nissanpatrol.com.au/forum...015/10/325.jpg
Pic of the 2 fuel lines comming up behind the heat shield like so...
http://www.nissanpatrol.com.au/forum...015/10/326.jpg
These are the fittings that can adapt frm hrd line to ur dash fittings...
http://www.nissanpatrol.com.au/forum...015/10/327.jpg
Cause evryone like a semi clean engine bayy...
http://www.nissanpatrol.com.au/forum...015/10/332.jpg
Flywheel fitted..
http://www.nissanpatrol.com.au/forum...015/10/333.jpg
http://www.nissanpatrol.com.au/forum...015/10/334.jpg
Clutch sorted...
http://www.nissanpatrol.com.au/forum...015/10/335.jpg
http://www.nissanpatrol.com.au/forum...015/10/336.jpg
Getn real close to dropn this bad boy in...
http://www.nissanpatrol.com.au/forum...015/10/337.jpg
Pic of the fittings to go frm the hrd line to dash six fittings...
Will drop the fuel tank this weeknd and mod my zd30 sender and finish my fuel system...
http://www.nissanpatrol.com.au/forum...015/10/339.jpg
http://www.nissanpatrol.com.au/forum...015/10/340.jpg
http://www.nissanpatrol.com.au/forum...015/10/341.jpg
http://www.nissanpatrol.com.au/forum...015/10/342.jpg
http://www.nissanpatrol.com.au/forum...015/10/343.jpg
Fuel system sorted...
Pics of modified sender... walbro pump and isolated bulkhead fitting...
Got a bit of spare time todayy...
http://www.nissanpatrol.com.au/forum...015/10/386.jpg
http://www.nissanpatrol.com.au/forum...015/10/387.jpg
http://www.nissanpatrol.com.au/forum...015/10/388.jpg
And shes in...
on youtube theres a series about a shop in the states that does a conversion kit for an 80 series. For memory the kit contains everything youll need to complete the conversion.
Just waiting on loom nw..
http://www.nissanpatrol.com.au/forum...015/10/441.jpg
http://www.nissanpatrol.com.au/forum...015/10/442.jpg
Ac lines done..
http://www.nissanpatrol.com.au/forum...015/10/443.jpg
Installd this carbon canister.. tuckd in tidy next to my 2nd battery... everythings looking tidy almost like factory fitted..
http://www.nissanpatrol.com.au/forum...015/10/444.jpg
For reference if any wants to knw what oil filter to use with these ls muscle pan sumps..
Are you happy so far???
Ye wish i done it sooner...
