Welcome to the forum mate.
Now that you're here why not drop by the introductions page and tell us a bit about yourself and your Patrol.
Tony
i think scotty could do with a recovery kit of a different kind this morning.
I have most of these things does anyone know where you can get a decent UHF from?
Is it easier to buy a recovery kit with everything or make it urself and I don't have a winch on my patrol is a hand winch just as effective I'm on a budget
Ok so better to get a UHF and recovery kit then a electric winch initially then when I've got the funds get a winch but yet again which recovery kit
Thats just to start with right
Cause I've been reading and everyone says don't share effectively get ur own recovery gear
I just picked up a decent kit on sale for $199. It's a warn kit with a bunch of goodies including the pulley block, tree protector, tow strap, snatch strap, shackles, bag, gloves, etc... They are on sale at Autobarn at the moment, they also had a basic kit for $99, i don't see why you would go without one when they are that cheap. Also, i assumes that warn wouldn't put their name on crap so yeah, correct me if i'm wrong :)
Awesome read! Just one point ... my Y60 has tie-down points at the front end only, so any recovery gear seems to be useless (unless we sling it underneath on the chassis)!!
Living in Port Hedland I find it is incredibly hard!! So far two options presnt themselves to me, make 'em my self out of 10mm plate steel or buy them online from Maquarie 4x4 Centre (http://www.macquarie4x4.com.au/index...ry%20Equipment). Does anyone have any alternatives??
cheers
C
Thank you. Sorry for what may seem a stupid question, but what do you store it all in? Bag or box?
A lot of "kits" come in their own bag. For example the ARB pictured below. Even if you get bits and pieces seperately, a recovery "bag" can be bought on it's on.
And then a lot of people store their gear neatly in the rear draws as well. Also pictured.
Edit: ** Not affiliated with below pictured brands at all. I just randomly plucked pics of google to show as examples.
http://www.nissanpatrol.com.au/forum...id=53425&stc=1http://www.nissanpatrol.com.au/forum...id=53426&stc=1
Thank you for the must haves.
The other thing to remember when buying snatch straps is to not go too big. That's because if the strap is too heavy it will not extend/stretch as much as it should and will transfer a lot of the shock load into the recovery points. When the straps are the correct rating they will extend at the correct rate and in effect absorb some of that shock load from the moving car.
The general rule of thumb is that the rating of the snatch strap should be 2.5 x the weight of the lightest vehicle involved in the recovery. For our Patrols the 8000kg strap would be the optimum weight. This is another reason to bring your own snatch strap. For example, imagine trying to recover a much lighter vehicle (e.g. any Suzuki) using a snatch strap rated for a Patrol. It would not extend and probably start breaking things off the car. If they had their own 4000kg strap then there would be no problems as it would work for their car.
I wouldn't recommend making your own there is a bit more in it than just cutting out a shape and bolting it somewhere'
@ growler not having a dig just saying , as its inviting backyard mistakes IMO.
I believe I have the only NATA tested front and rear recovery points in Aust.
any others you see the same shape are just copies and not rated.
One thing not mentioned in this thread is a decent compressor, a must for any 4x4 outing,
I would avoid the ones with a thermal cut out, for under bonnet installation
another old thread dragged up.
You could buy an ammo box and use that as a dedicated recovery box,
that way every thing is in one place
Hi, my first post.
A lot of good info here and thanks to the contributors.
Just upgraded / retrograded from a 2012 Navara to a 2009 Patrol.
I've always carried (rated) recovery gear in my Navara after going for my my first (solo) run from Tim's Thicket to Preston Beach WA. All I had on that run was "thankfully" a shovel and it came in verrry handy, which I'd thrown in as an off chance!
I'd point anyone's attention to the simple diagrams that riggers use for slinging in regard to recovery straps (strops), the various ways that they are connected e.g. single, double/basket. choked etc significantly vary the rated load capacity of ANY sling. These diagrams/leaflets are readily available online.
I also would advise that everybody does need to do themselves a favour and buy their own recovery gear, minimum I believe is rated shackles x 2, a recovery hitch (Reese style) and a rated strop/sling and probably a snatch strap also.
Please be aware of the need to add a dampener e.g. blanket/coat/sack to any line under tension which has the capacity to have you in the line of fire.
Enjoy and stay safe.,
G'day 4bye,
No, not a rigger mate but work offshore with equipment that has it's own (big) electric winches, hydraulic A-frames etc (ROV).
Also learnt a lot of this rigging stuff too many years in ago in basic engineering theory in the RAN.
I'm electronics/electrical by trade but current work involves hydraulics too, so as I said in the intro, know a bit about everything apart from engines.
In my early fifties and continuing to learn, every day!
Cheers,
gropertoo
Really handy video.
Great thread.
Does dragging a unprotected chassie through a sticky situation pose a greater load than one with plates fitted ??.
Would have thought any protection plates underneath would have a sled effect and thus help reduce resistance to recovery.
Has any one noticed a vehicle with plates fitted seems to be easier to recover?
