The man loves to live dangerously! No fuse needed.
Based on what you’ve described, it could be worth checking if there’s any resistance in the earth connection, even if everything seems fine visually. A weak or intermittent ground could cause that “squeaking” noise since it’s not allowing enough current to flow through the circuit. I’ve seen this kind of issue before where the connection looks solid, but cleaning or tightening it up fixes the problem.
If you’re still stumped, you might want to check out bosshorn.com for some additional tips or parts that could help troubleshoot electrical components like this. They’ve got some resources that could be handy for figuring out what’s going wrong.
