dannypatrol
Hey guys,
I bought a Nissan Patrol GU 1998 TB45 dual fuel (297SRR) second hand to do a big lap in 2016. Unfortunately, I have been a bit unlucky with it and I might have bought a cat in a sack.
I found out that the brakes never should have passed the RWC (the ironic thing is that a got a mechanic to check it all out but this was the same mechanic as who gave the RWC). She also overheated on the beach a while ago. I had the thermostat, viscous fan and radiator replaced (see previous topics) and got it checked for broken heads. I thought it was fine, but I hardly use my car, maybe twice a month and I didn’t had any problems. But since a roof rack and rear bar has been installed, the last couple of months temperatures have been off and I am too worried the overheating get worse or it will just break down. I have an ECUtalk and I see the temperature increasing to 97, drops to 95 and then to 115ish. The thermostat should open at 87 so I am wondering if the thermostat is broken (was a brand new one though), so I got a new one but haven’t placed it yet. In addition, I figured it might be good to place an aftermarket sensor in the top radiator hose.
Now the car needs to go for a big service:
• Transfer oil change
• front/rear brake pads and rotors replacement
• rhf brake caliper replacement
• brake fluid flush
• front wheel bearing replacement
• gear box and engine mounts replacement
which will all together be 4-5k according to quotes from mechanics
The worry I have is that the temperature problems wont be solved and that I invest 5k but then still have a car I will not be able to use for a big lap. This and last year were a bit of rough years mentally and these car problems make me more worried than normally (I am normally pretty relaxed). It really kills my motivation of planning the big lap at all just because of the risk I wont even get to that point (I still havent installed my dual battery system etc). Hopefully the new year will be better and I will have new energy to get motivated again to work on my car and learn how to fix things.
Just wondered what the best way is to figure out if I should continue with this car or not.
I think:
(1) replace thermostat and install after market temp sensor in top hose. This will then add extra info in addition to the ecutalk and will tell me if temp sensor is wrong
If cooling problems solved, then get all repairs done
if not....?
