Im leaning towards JoeG's explination
If you did nothing but grease the kingpins.
Did you put the assembly back in the same orientation "not spin the carrier around".
I'd bet Originally The flat spot/dibbets in the bearings were lined up giving excess play.
Arrhh, now there misaligned since they were removed & greased, think you've spun the carrier upon reassembly.
this may explain the sudden perceived improvement.
Thanks for the responses so far.
I took the car for a good drive and didn't get speed wobbles at all. As an added bonus (for me, as my attempts at mechanical things don't always go as planned!) there were no remaining screws/bolts, no scary noises, and the steering felt good.
Robo, there is a good chance that the carrier was not set back in the same orientation as it came out. Visual inspection (totes scientific) ended up with me deducing that there is no "wrong" way to put them in. Given that I didn't resort to callipers or other measuring tools, my assumption could be very easily proven wrong.
If the assemblies do have a correct way that I unwittingly got wrong, what would be the result? Given its a car, I assume "catastrophically expensive" is the answer, but what are the details?
so long as they are oem assemblies your cool putting em back in.
yes just the orientation and wear points have/possibly moved
ya can buy off set carriers which move the caster,
the lug the bearing fits on isn't centered.
and offset bearing cups are also available.
