When you lift your truck the axle is moved to one side, to correct this you need a longer p/ard and drag link. Pulling off the wheel leaves the steering box in a turned position, how badly this is noticed depends on how high you lift the truck
I have had both Ironman and tough dog within the past 5 years. Not much in it but i would choose tough dog. Tough dog to my knowledge just copied rancho so maybe research how goodbthey are.
I would recommend adjustable shocks from tough dog as they make a huge difference when road/track surface changes along with vehicle load.
Ok, so I figured I needed to outline my intended use of the Patrol to better narrow down exactly what I need/want in a lift kit, so here goes.
I will be hauling ~200kg of stuff a couple of times a year in extreme cold on the winter roads with varying surfaces, rutting, etc. (approximately 2700km round-trip)
Minus these 2-4 times hauling supplies on the rough winter road, I will mainly be driving on dirt roads (varying levels of smoothness) in a small community, hauling small loads here and there with passengers. Could be considered light off-roading.
So, with all of that in play, I need something durable enough to haul a load in extreme conditions, but comfortable to ride in when empty.
Some places I've read have recommended going with good solid springs, a foam-cell shock on the front, and gas on the rear. Other places have said go adjustable shocks all the way around or just in the rear. I need some advice from other more experienced in this. What would be the optimal setup for this scenario?
Always better to give as much information as possible.
I'm not expert......
So I would send that information to as many suspension/4x4 places as you can.
Asking about warranty and maybe even to suggest two set ups.
Then follow it up with a phone call to the ones that you like.
Toughdog/Ironman & OME with light (0-200/300kg pending brand) shocks in my opinion would be suitable. Adjustable shocks just gives your suspension increased ability to function pending on payload and road surface. Which it sounds like you need. The price difference on adjustables is negligible so i would get them all round.
Hope it all works out
