Mig tig or stick it doesn't matter it'll all do the job if prep is right. And just disconnect the battery then you can weld it on the car
I would maybe leave the diff oil in to and drain and replace on completion as the oil will absorb some of the heat. Diff oil is very thick so as it heats it will thin out . It looks like most of it leaked out anyway.
Good luck. As Macca said, any type of welding will get it done.
