sooty_10
1) The e-locker's wiring is so simple, standard wiring to a relay and then one (twin sheathed) wire down to the locker. It's not exactly hard to diagnose if there is a issue with the lockers wiring. 2) My winch runs from my start/Main battery, as does most people, I run everything else I add through the aux battery including the locker. I don't see how the e-locker is going to disengage with the winch running. Surely a compressor drawing huge amps is going to have more issues with the winch running? 3) I definitely understand this point, I've seen plenty of wires as you've described, usually I find it when they are exposed to the heat (near exhaust) or poorly sealed terminals/connections. There are ways to better seal and ensure you increase the life of any wire or connection if you can be bothered. Most people would likely have a dual batt setup, usually before getting lockers. My locker runs from my Aux batt and as the e-locker only draws around 5 amps (rated at 8 amps max) I'm pretty confident the locker would stay engaged long enough to get to where I need to, and still have lights running. Let alone the compressor is going to be more of a burden on a battery than the e-locker. Also as with any electrical circuit it should be fused, which it does comes with, so any broken live wires are simply going to blow the fuse. ;)
