Jonesy_sa
Hi guys,
Uni exams are over for another semester so time to look at the 4x4. I will start with a basic service, then fault find and replace as required (hopefully addressing the horrible rough idle!!).
Can anyone confirm what filter options are available? I have read a number of times not to use the z9, however i read the Z115 is a cheaper larger version of the Z170 (Z170 used in restricted access areas). Online Ryco stated Z115 however in a store their guide mentioned Z170. Is everyone sticking with the expensive Z170 or is the Z115 fine?
For oil SCA has Shell Helix HX3 20W/50 on special for $24 for 10L whereas Penrite HPR 30 is about $38 5L ($76 for 10L) from SCA! The previous services used whatever cheap semi-synthetic oil was available (so im told). The HX3 is Shells standard recommended oil for the TB42, however i have not used it before; i imagine it will be fine?
