I've nearly always had a 6 dBi gain antenna and travel the remote beaches, dunes of NW/W Tassie and happy with the results. I'm also no expert !! but do believe it matters where it's mounted
The short answer is no, at least not to any advantage for what you are after... you would be more than halving your power for starters.
The long answer is you can deliberately run two antennas for an apparent gain but it is directional and very very specialised and is called co-phasing.
It is used to produce specific radiation patterns that would be terrible for a most 4WDers.
If the antennas aren't co-phased but still coupled the radiation patterns would be very unpredictable and vary with frequency versus distance apart if they are on the same plane.
Thought it wouldn't work. Just didn't know why...
Thanks.
run 2 antennas....just use one of these ...instead of a triple , get a double one ...switch over when you want to..there is another connection on the other side that goes to the set
Attachment 44996
Oo where is that one from ? I have 3 bases on my bar but only have a 2 way splitter
Here is a twin.
http://www.ebay.com.au/itm/2-POSITIO...-/190688386130
