I wonder why Kaymar went to all the trouble making a bracket If the fit alright
40mm out and 60mm up from memory.
but its not about 35 is it
G'day ThomasWatson,
I have a 285/75R16 Dick Cepek FC-II on a 2001 GU Patrol, on the original rim and it fits ok, however, you need to adjust the bracket on the door, (remove the wheel and look internally to where the bracket bolts to the door, undo and remove the 4 x 17mm nuts and lift the bracket up to the next bolt patten, this allows the 33 to fit without rubbing on the bar!)
PS, MudRunner notice when i was down in Victoria at Christmas that my Tyre was rubbing on the bar and not allowing the door to shut properly and advised me how to fix it.
Regards,
RLI
Also do I have to remove my mud flaps to fit the tyres
