Re: Steel working question??
Quote:
Alitis007
I might be getting my info mixed up. Annealing the steel with welding to remove its weaknesses or stresses (oxygen is a weakness in steel) and slowly cooling it to make it stronger?? Thats my understanding but i could be wrong lol.
Yes to a point, your not actually removing anything, but changing the properties by heating and cooling the material.
Quote:
Would 4mm plate be thick enough for the front bar??
Yes, you could use 5 for the centre part where the winch sits, but if given some shape like the bigger named bars 4 will be plenty again.
Again big named bars are 3mm.
Which joint are you saying to use ??
Attachment 26821
Finishing off the project is easy i have flap discs, grinding and cutting discs and a few different die grinding dremals (stone and steel) its just the fine technical details are what puzzle me ATM.[/QUOTE]
No.1 mate. Lots of tacks on the inside, full weld the outside, but stagger the welds...
Owner of
Westy's Accessories
If you used a design like this
http://www.nissanpatrol.com.au/forum...2013/03/55.jpg
4mm will be heaps as the folds add a lot of strength...
Owner of
Westy's Accessories
No need for bending, just a little more welding... :D
Owner of
Westy's Accessories
benno77gu
hi alitis007, dont worry yourself the metallurgy of steel(only need to worry about this stuff on higher grade steel such as bisalloy) ,your only using mild steel just tack the whole job together first and stagger the welds around so it doesnt pull out of shape, cheers
Yea sorry to confuse people. I do tend to over explain a bit.. wife's always telling me to shut up, so please if I get off track feel free.. :D
Owner of
Westy's Accessories
