patch697
Interesting read.... Im not sure I fully support your findings but it has intrigued me enough to do some research of my own on the subject.
I have however had a similar problem with ignition leads which I corrected by installing high performance low resistance leads (1000 ohm from memory).
Installing low resistance leads in your setup would not go towards supporting your theory of resistance causing the release of unused energy however so it may not be a path you'd choose to take.
Best of luck with your research & keep us posted on what you find.
