Backyard trial run of the awning , had to make new poles , but happy as with the outcome
Attachment 48373
Attachment 48373
Pick an axle set up that you think will exceed your build weight 40mm square is heaps ,
being small you may want to look at the independent style but no travel.
Ive used Orac greasable shackle full off road for my camper, just take some leaves out to suit.
avoid slipper spring set up, will not cope
The whole thing is high now , the annexe walls are now 300mm to short , with 700mm of ground clearance it's way more capable than the car , even the water tanks don't hang below the chassis rails , and the diff pumpkin on the car will hit before the axle does ,
Really looking forward to towing it offroad , bring on Fraser in a few weeks :)
Before and after
Attachment 48418Attachment 48419
Well done mate. Looks a treat now
Set up on Fraser , new chassis and suspension worked a treat
Attachment 49907
