It sounded great as you left
We have just put a 3.5" exhaust on the one I am doing up here. Sounds real nice.
Finally had a couple of hours kid free!!
Replaced the 4" inlet with a nice wanker shiny alum one!
Also installed the line for the td42t vacuum to a T on the alternator Vac line, dual Vac!!!
Brakes are a lot better now!
Would it be worth getting a bigger canister now?http://www.nissanpatrol.com.au/forum...2017/07/40.jpg
We were way off too. The line tucks right up under the sump mounting to the timing case and block as below.http://www.nissanpatrol.com.au/forum...2017/07/43.jpghttp://www.nissanpatrol.com.au/forum...2017/07/44.jpg
Oh wow, yeah that looks heaps better. I wonder if that sound deadening mat on the sump does much, might try it out one day if i have any leftovers. .
Soooo we just did the snow trip and as some of you know my intercooler has been leaking and I've gradually being losing boost and power
Can't believe the good members on that trip here haven't bagged me out yet, bloody good blokes!!!
So I'm sitting in my Gq in thick snow, Saturday morning cold as F ready to do a day trip of tracks.
Trying to reach operating temp so pull the idle out and nothing happens????
Annnnd it turns out my IC and piping is 100% fine!!!
At that moment I pulled the idle screw out and no response it clicked I have an issue with my throttle cable!!!
Low and behold the bloody nuts have been slowly working loose over the last month...lol
I blame Matty really, totally his fault for not asking me to check if the bloody throttle control on the injector pump has been slowly winding out over time!
So Matty vic asks for a 10mm, then a 12mm, then a 13mm in which we thought 13? And then finally a 14mm spanner, 23 seconds later my beast is back, better than ever!!!
Embarrassment!!
Classic ! ! Matty to the rescue again [emoji6]
