thats feckin funny
thats feckin funny
Is the donk in yet? LOL
Wow man its all happening.
Good luck with the Turbo, as yet don't understand what happened but if it caused the problem....
Also had no idea how different the engines are, bit of a fiddle to make it all connect, fit and line up. You sound like having a challenge in front of you, best of luck.
Anyway it is good to read you are getting somewhere with it all, good luck mate.
Dropped off clutch and flywheel for balancing and lightening at Duggan.
Very time poor during the week but managed to get both 18th century gaskets off and clean the oil cooler and water pump.
Also noticed the dip stick compared to mine is a lot longer with longer min max line then worked out the td42t holds more oil than the silver top.
Recon you'll get all the bits ready for the weekend?
No chance mate. I tried to work out all the bits I need but there's some things I've already missed and things will crop up.
I need to get some bits on to work out what else I need like correct lengths of line for the turbo, etc.
I was hoping to get everything done so we can go somewhere local for Melb cup but it looks like next weekend will be the weekend of getting things on and working out the final bits for final install Melb cup.
I'll see how I go though. Mums back from hospital so I need to spend time with her too.
We'll get there, I don't want to rush either. I can't find torque settings for the pulley on the water pump???
Yeah nice be good to get it going but no point rushing may as well do it premo. Won't be long tho can't wait. .
