Sorry to gatecrash JaySee.
@Ben-e-boy Whats your thoughts on them Autoreset breakers, from Jaycar from example?
Where would you apply them ( if at all) , instead of your regular reset-able breakers?
https://www.jaycar.com.au/chassis-mo...12vdc/p/SF4102
I have 2 in 2 different circuits. Each circuit also has a fuse with same rating as the breaker (30A).
And I've tested them with current and direct to ground contact and they trip instantly, and kick back in when fault clears. Fuse does not blow, these breakers trip faster than the fuse-out.
