Ben-e-boy
It'll be the same spot judging by the orientation of those marks, my guess is at full extention, when Installing big bore shocks you cut away the back of the bump stop pad which has been replaced by the airbags mount to clear the bigger bore shocks
Remember that when articulating, at full droop on that side, the lower control arm is swinging down and forward towards the front axle. The upper control arm is doing the same, but because it's shorter it is rotating the diff therefore the pinion downwards. At the same time the panhard rod is swinging down and pulling the diff towards the drivers side because it moves on a perpendicular axis.
