yes mate. Is Big Is Good! :p
How would you hold it, your arms aren't long enough. PML
Time for a new rear bar with spare wheel carrier maybe?
The tread blocks actually makes it pretty easy to handle. Bloody heavy by fairly easy to manage. I fitted the tie downs out far enough that I can drag the wheel out and not jag on the tie downs.
I will install a shelf across just above the tyre so I can pack on top. I will remove the compressor from the box on the wheel arch and mount it on the floor in front of the tyre too..
Most of the guys I roll with have their spare inside the car like that. I will manage. Need the shelf to handle the 45lt Fridge would be ace and somewhere to mount the travel buddy with acres through the side window again is the plan.
