ummm you have a nissan patrol sticker on your windscreen? you have a crack in your headlight? tyres stick out of the flares? and your shed is very neat? what am i missing here?
The scoop !!!
Sent from my SM-T705Y using Tapatalk
Looking very good jono. Have to admit i think Snorkel upgrade with a ram head is on the list someday soon. . It is ridiculously loud and annoying having it right next to the window sucking away like crazy. . .
post dig!
Just wanted to clarify our convo.
You nutserted from the inside as you mounted yours from the snorkel directly across into the body thus no hope in hell without removing battery tray etc.
Mine was done with brackets and all work was done externally.
You get too the bolts via the inner wheel guard and is very easy.
Fitted a Ctec DC to DC charger yesterday plus tidied up a bit of the wiring... Also when I fitted the new air scoop I had to move my water jets for the windscreen but of course snapped them when trying to pull the hose off.... Thank god Mudski sells the jets and new hose.. they have never worked so good ever.
Also on the bummer side I have no aircon again... it seems when JPC fitted my turbo they pushed on the line a little too hard and was putting too much pressure on one side of the O'ring so it slowly leaked.. now I have to have it filled again for the 3rd f%$king time.
Ouch AC gas isnt exactly cheap 😠
Should be doing it for free old mate if it's their mistake surely????
I know jpc are awesome but...
KSR auto air are the gurus in Melbourne for air con and they couldn't find my fault on my gas loss even with their dye after a refill.
He said come back and we'll do it for free if it empties and well redo the lines/fittings to be sure!
I would not be able to prove it was jpc..
I dont have the option to shop around and network air have been brilliant,not there fault.
Turns out i was wrong and the line was split along the firewall in another spot..
This is the second line along the firewall that has failed over the last 4 years so on Saturday i will do away with this and replace with hose instead.
So i apologise too jpc...lol
Today after work i replaced the wiring that came with my led spot lights as they were not up to the task so hopefully no more blowing fuses.
Who did the last valve set on it?
Go see Bob and he can makd up new hoses. I had a hose that was leaking and he removed the old and crimped a new hose in between the pipes.
Plus I like going to Bob at Network Air, he gets so excited about his job. Quite funny to watch him.
Whats your f%$king problem........
You know what.... get a dog up ya! !!
http://www.nissanpatrol.com.au/forum...015/10/289.jpg
Not gonna answer me?
