Ring places that possibly do engine conversions etc... There's a LOT of barra conversions going on. Therefore a LOT of redundant gearboxes laying around somewhere.
Thats a great idea. Or @mudski join a Barra conversion group of FB and ask if anyone has a gearbox in the shed.
What are the chances!
I replaced the fuel filter a while back and noticed the lift pump wasn't holding pressure anymore.
It would need a good 20 pumps if left sitting for the night.
Ok, easy, it has to be what I have just done. Check bleeder, check drain, check fuel filter, etc.
Everything looks fine. I took it off and on again multiple times.
I have never had a problem with my fuel pressure.
I just found this whilst waiting for Mia's school bus. That little tiny injector bleed return line looks to be the culprit.
What a perfect time for that to happen exactly the same time as I replace the filter!!!
Attachment 88018
All good. I found a s/h box from a 2008 low 100thou on the clock box. George will be doing the r & r for me. Now I'm thinking do I get the Mark 10% overdrive reduction gear now, since I have saved over 2K. This would bring my revs at 100kph from 2450 to 2205rpm.
Hmmm.
Mocked up with black tape, another Wacky MB concept [emoji2957][emoji23]
https://www.nissanpatrol.com.au/foru...2024/05/11.jpg
https://www.nissanpatrol.com.au/foru...2024/05/12.jpg
Not sure if I love it or hate it yet [emoji848]
Keen for your honest helpful thoughts prior to welding Team NP.com.au?
Certainly will keep I believe our pesky local Hills bugs from ram feeding into the airbox, open passenger side window for a Navi would be a lot more bearable too I imagine [emoji1696]
https://www.nissanpatrol.com.au/foru...2024/05/13.jpg
The 30 degree downwards, slightly twisted final bend theory is for parked up outside/overnight camping torrential rains protection.
Have had previous plastic family GU wagon truckster ram head snorkels fill airboxes overnight and believe poor @Rossco ‘s GQ once did the same nearly hydro-locking his beast on morning startup [emoji51]
EDIT: Besides looking a little kooky, not powder coated yet [emoji23] Could the extra nearly say 800mm of 4” pipe potentially hinder its air intake? I’m only chasing 150rwkw again [emoji1696]
Looks good, the extra pipe length would add restrictions in the order of 4 decimal places - not an issue, clever about the drop end to keep the water out. I have never had a problem with my forward facing safari head, or maybe the water simply was very small and evaporated from bonnet heat?
