I am newbie here, my Y60 have TB42E and cylinder 6 injector pulse is missing, kindly help.me to get wiring diagram
Welcome to the forum mate.
All 6x injectors are fed from the same pulse. If #6 has no pulse, it is in the wiring/connector on the fuel rail.
Don't have a wiring diagram. Injector wires are green and white. All the wires for the injectors are fed of the one green and white wire in the main connector plug for the engine above the alternator.
There is a stiff wiring loom running right next to the injectors that carries injector wiring and wires for other sensors and solenoids.
Like I already said - if you are getting power to the other 5x injectors you have power to the injector wiring.
You have to trace the problem wire back to find the fault, but it will be in the loom beside the injectors - so unwrap the loom and look.
Kindly share me which country you are writing from.
