Remote programming not working
Hey fellas,
Having troubles programming a remote fob i got of eBay for my 1999 Ti model its a tb45. I've dug around to see if i have the keyless entry module up near the glovebox which i have. I'm stuck on #3 and #4 where it says doors will unlock but thing is every door unlocks after it gets into programming mode but the drivers door doesn't in which in #4 says to lock the drivers door?
Have also noticed in other write ups about the hazard lights should be lighting up in programming mode mine doesn't
The istructions i was given are :
Programming instructions
1 –Sit in car with door and window locks closed
2 –Lock drivers door with manual switch ( NOT POWER SWITCH)
3 – Insert and remove key from ignition 6 times within 10 seconds – Doors will now unlock
4 –within 2 seconds, Insert key into the ignition and turn to accessories position and lock drivers door
5 – Press any button on the new remote – locks will cycle automatically now
6 – Repeat steps 4 & 5 for any existing or extra remotes
Note- when the above procedure is unsuccessful make sure step 4 is performed quickly as you only have 2 seconds to perform this if at any stage you make a mistake you will need to start over again and will need to remove key from ignition open and close door
