HI guys my 2012 ST has 140000 kms shocks seem to be RS
What brand are a good replacement ?
Used as every day transport & towing camper trailer on week ends
Thanks Regards
Rob Poynter
Thanks Regards
Rob Poynter
Old Man Emu gets my money. OME Sport is very good, mine has 240,000kms on the suspension and still going strong. when they finally die i will go tot he ARB OME BP51s which are next level but at this stage the Sports have done an amazing job.
Yeah OME Sport would be my choice.
I'm running Tough Dog adjustables (45mm) and I reckon they're darn good. Ran them on the Madigan and they got blisteringly hot but just kept on going. Great being able to adjust them for when I'm loaded or unloaded.
Ran them on the old Navara as well, I can't fault them.
Another vote for OME. 170,000 km & still going strong.
How do you assess if the shockers are operating correctly ? I had a new OME system installed on my patrol from new. At 50,000klm, I pulled the shocks off and found the compression rates varied considerably from side to side. I tossed them for Koni adjustable hydraulic and at 110,000klm rebuilt them- or Koni did, simply replaced the metering discs, and back to square one. The Konis have a 3 or 4 stage adjustment and I found the compression rate side to side was different by 2 clicks on the rear and 1 click on the front. For me, the results have been very different than others.
The shocks sole responsibility is to control the spring, converting that kinetic energy to heat.
If you put your weight on on corner of the vehicle and bounce of it, basically the spring should compress, extend and settle. Any more movement and the shock isnt really working. (Not necessarily faulty, not doing its job)
