Just finished doing an axle seal on the rear left and job was completed in less the 30 min.
You only need a 19mm spanner for the calipers and and 17mm for the housing and a large Phillips head for the disc plate.
Also helps to have a decent sized pry bar and a seal driver.
Remove wheel and caliper the disc.
Undo 6 17mm nuts and with a hammer gently tap the main hub assembly out.
The whole lot will fall out with the axle.
Pry out old seal and with a oiled up new seal and using a seal driver replace.
Of course clean as you go and re assembly is reverse of disassembly.
Very straight forward.
Job can be done in 20 min.
Attachment 57673Attachment 57674Attachment 57675Attachment 57676Attachment 57677]Attachment 57678
