Hey all,
The old girl GQ needs new suspension bushes and I was wondering if this has them all or if i need to get more not contained in the kit http://www.ebay.com.au/itm/Full-Susp...3D330839511333
Also whats the best way to do this?
Hey all,
Yes mate that has everything you need, I would suggest that you consider spending the extra money for genuine bushes instead of those aftermarket ones though. Genuine are higher quality and will last longer and perform better.
I second that. Whiteline bushes are good for your panhards. If your car has a lift, make sure you get castor correction bushes for the radius arms
Not a fan of drop radius arms personally, the only thing that really corrects a radius arm geometry (and castor angle) after a suspension lift is drop boxes. The reasoning behind this is that it brings the rear of the radius arm down to match the amount you have lowered the front diff.
