gday guys
After looking into the Maverick a little more ive discovered that it already has a Pertronix lobe sensor module installed with a bosch GT40R coil. I just wanted to double check how it should be set up in regards to a resistor coil and condensor as ive read a couple of times these things are normaly removed once the pertronix has been fitted. This is the set up I currently have:
Attachment 45921
cheers in advance
