MudRunnerTD
X2. Big fan mate.
If you are doing this alone without a mate close by then I'd recommend jackin the chassis up and put it on jack stands so the weight of the car is on the stands and the wheels are on the ground. If you set it up like this it simply can't move when you take off the old panard and is preset to the correct position for when you fit the new one.
The Panard holds the body centre over the diffs, if the body is sitting on the springs when you take the panard off there will be nothing but balance stopping it from shifting. Shifting even 10mm to one side you will not see until you try to fit the new one that you have setup the same length as the old one and now you need a mate to give the body a push sideways while you try and refit it.
