I was reading a thread and noticed high tensile bolts mentioned. With being involved in strong discussions involving raised voices at work, I thought I would make a thread about the blighters.
Firstly, high tensile bolts can be identified by either marks or numbers:
0 lines; Grade 1or2
3 lines; Grade 5
6 lines; Grade 8
then you have 4.6, 8.8 and 12.9 rated
Many people believe you should use HT for any pulling force. But Ht will snap not bend when stressed. I have been advised that HT is for taking strain along the shank from top and bottom, not from side.
But for more info look at these links below I found while making this thread:
http://www.qldcorvetteclub.com.au/te...talk/bolts.htm
http://www.offroaders.com/tech/Bolt-Identification.htm
hope this helps
