Got the front of my engine stripped down a bit this weekend, I am doing it to fix a water leak.
Over the next couple of days after work I will pull off the front timing cover and when I can get my mechanic mate to guide me I will remove the timing gears, IP and backing plate so I can get to the rest of the O rings and gaskets.
Is there anything else I should replace or check while I am this far in?
