Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Diff ratio tyre size speedo gear (pinion)
    Expert TuffTD42's Avatar
    Feb 2011
    Central West, NSW
    Here's a list of pinions to suit tyre sizes with accompanying diff ratios to get your speedo within specs. It worked for me for engineers. Got my speedo within 4% which is NSW law. cost from Nissan at the time $74. Or you can pay $220 for a Tyre match box. Cheers Jono.
    Diff ratio Tyre size Speedo gear (pinion)
    Part Number i.e. 4.11:1 ratio running 31” tyres 32703 - 31G 17 Change last 2 digits for gear you need.
    3.9:1 Ratio
    Tyre Pinion
    31 16
    33 15
    35 14
    37 13
    4.11:1 Ratio
    31 17
    33 16
    35 15
    37 14
    4.375:1 Ratio
    31 18
    33 17
    35 16
    37 15
    4.625:1 Ratio
    31 19
    33 18
    35 17
    37 16
  2. The Following 9 Users Say Thank You to TuffTD42 For This Useful Post:
    Endermore (19th October 2024), fixer982 (18th May 2011), GQPatrol89! (20th July 2025), Lexx (21st July 2014), Mrowka (30th March 2011), mudski (19th April 2021), Plasnart (2nd December 2018), snicko (6th May 2011), YNOT (28th March 2011)
    Feb 2011
    Shed
    45 Post(s)
    well done cheers mate helps to sort out the dark art of speedo v tyres v ratios
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Top find and post mate!!! Well done and thanks!!
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Great Post mate, im sure will help out a few members at some point
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  6. #5
    Western suburbs of Melbourne
    11 Post(s)
    This will come in handy, that's for sure.
    Sent from the secret chambers of our secret society, on a secret iPhone, with a secret pin code and eye retina scanning from a secret peep hole, just don't tell anyone OK, cos it's secret........
  7. #6
    Maroochydore, SunShine Coast.
    Top marks TD42
    Drive is 04 DX wagon, 165Ks, Dual Batts, 12000kg Warn in steel bar, Snorkel, Xray 220 Hid Spots, Cruise, digital EGT, Draws in back with power box, 40Ltr Waeco for the essentuals
  8. #7
    Advanced Dmwlking's Avatar
    May 2012
    Australind W.A
    Last time i got some gears from nissan. not many in stock in australia. not sure if their is after market parts.
    005 GU PATROL 4.2TD WITH SAFARI TURBO, SNORKLE, LONG RANGE TANKS,BULL BAR ,DUAL WHEEL CARRIER, ROOF RACK, TIGER WINCH, STEERING DAMPER , REAR DRAWS AND ENGEL SLIDE,35L WATER BLADDER.
  9. The Following User Says Thank You to Dmwlking For This Useful Post:
  10. #8
    Advanced
    Jul 2014
    Thanks mate, an unexpected help for a problem I thought I'd have to just 'follow the traffic' for!
  11. #9
    Patrol Guru
    Apr 2011
    Melton
    You can adjust the GQ's speedo
    There is a trim pot on the dash pcb - I have posted details elsewhere
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
  12. #10
    Nov 2017
    how good are you, excellent home work, I have cross checked your post and you are 100% correct with your ratio verses pinion drive gear again WELL DONE
