Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Autron gauges
    Western suburbs of Melbourne
    12 Post(s)
    Autron gauges
    Just wondering if anyone has used or is using Autron gauges and their thoughts on their products, as I am in the market for new boost/pyro gauge and the dual battery volts gauge.
    https://autron.evolveshop.com.au/epa...52.27.091014.1
    https://autron.evolveshop.com.au/epa...52.27.010105.5
  2. #2
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Read these threads:
    http://www.nissanpatrol.com.au/forum...=autron+gauges
    http://www.nissanpatrol.com.au/forum...o-you-guys-use
    If you do a search on Autron gauges you will find a few more threads on this topic.
    Todd
  3. #3
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Check out this existing thread..
    http://www.nissanpatrol.com.au/forum...923#post165923
    I have one and the only real issue is that it is a little bright even when dimmed. As you will read in the thread above some people have fitted a second dimmer to bring it down further. Keep in mind i run my dash at fully dimmed on the nissan dimmer.
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  4. #4
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I installed a set today (Boost/EGT and Dual battery) - both with ammeters. The battery gauge works well but I am having a problem with the Boost/EGT. Spent all day installing them so I wil have a fresh look tomorrow. The sure do look the part (in the pillar pod). I'll let you know what happens.
  5. #5
    Jul 2010
    Thurgoona
    7 Post(s)
    After a good nights sleep and a fresh look - the problem went away! All is now good and the gauges look and work great. I went with the extra current display in each gauge so that I can monitor what is happening in each battery. The installation was not difficult - but very time consuming. It took me a full day to install it all (not counting drilling and painting the pillar pod, which I did previously). It would be interesting to see what an auto elec would charge to install a set (anyone have an idea?).
  6. #6
    12 Post(s)
    Finally pulled my finger out and ordered my Autron EGT/Boost gauge and dual battery gauge with pillar pod.
    Close to a grand to supply and fit. With an extra dimmer switch for the gauges.
    At least now, well once fitted, I can keep on eye in things or at least know what it's doing.
  7. #7
    12 Post(s)
    Booked in for Monday. Can't wait.
  8. #8
    Jul 2010
    Thurgoona
    7 Post(s)
    What did it cost to fit? Just wondering because it is a lengthy process.
  9. #9
    Advanced Steveo_the_Devo's Avatar
    Oct 2011
    Wollongong NSW
    Do you have the details on the dimmer that you used? I'm keen to add another to my gauges
    2011 CRD with a bunch of stuff bolted on
  10. #10
    12 Post(s)
    Quote Originally Posted by BillsGU View Post
    Close to a grand fitted, but I did save a few hundred by having a Taipan exhaust with a sensor point in exhaust already so they just screw it in.
  11. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    BillsGU (11th September 2012)
