Results 1 to 5 of 5
Thread: Multiple electrical failures
    Dec 2022
    Hello EVERYONE, (NISSAN Y61 TD6) I have a sudden electrical failure, the tachometer does not work, preheating light off, air conditioning (only air conditioning, air conditioning does not work) and the Czech engine light (d usual it stays on since I changed the pump to a mechanical pump) but now it is off. I checked the fuses and relays all working. Do you have any suggestions where this multiple failure could come from. Thanks in advance. FRIENDLY
    (sorry for my English)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Does the Y61 run a 24-12V reducer? In the Y60 it was in the passenger footwell kickpanel...
    1989 LWB 5-Seat, TD42
    Quote Originally Posted by kais ch View Post
    If the fuses aren't blown (you checked the engine bay and I'm cab boxes right) have you had any damage done recently? Sure sounds like some damage to the loom of you aren't popping fuses
    Dec 2022
    hello
    Thank you for your answers
    Y61? 12 V. I have 03 blue relays in the fuse box in the passenger compartment
  5. #5
    Clean your earth lead connections up. Also add another from the gearbox to the chassis. Patrols are know to have shitty earth connections.
    pollenface (25th January 2024)
