Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
Thread: DIY Wheel Bearing Adjustment.
  1. #51
    475 Post(s)
    For waffling on clarity
    Accidentally bent my 30+ year old bestest Crowbar some 10 years ago and never looked back
    109 Post(s)
    And they say Bonsai landscaping is childs play....
  4. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (27th August 2022)
  5. #53
    475 Post(s)
    Focus, and try hard enough on Australian Rum and you too Plassy Mate could bend a spoon for mechanical purposes too
    Rossco (28th August 2022)
  7. #54
    Apr 2021
    Brazil
    But bend it with psychic power alone, for more fun!
  8. The Following User Says Thank You to BrazilianY60 For This Useful Post:
  9. #55
    475 Post(s)
    GOLD BZ Mate
  10. #56
    Apr 2021
    Brazil
    Job done! Thank you lads! Turned the locking nut just one click and the play was gone.
    It surprises me that there is no gasket on the hub mating surface.
  11. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cremulator (30th August 2022), MB (30th August 2022)
  12. #57
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    There should be...
    worst case knock one up out of beer box (cardboard usually found on dozens, not the corrugated boxes that 24s come in...)
    PITA, but a hole-punch set (scissors if you're a masochist) will have em knocked out pretty quick.
    1989 LWB 5-Seat, TD42
  13. The Following 2 Users Say Thank You to mihit For This Useful Post:
    BrazilianY60 (31st August 2022), MB (1st September 2022)
  14. #58
    sunshinecoast
    my 2011 gu had no gasket there from new . i just put a thin wipe of wheel brg grease on the mating surfaces , that should stop or slow the progress the passage of water across the joint . i have had my hubs under water a few times and there was no signs of water ingress even without the grease when they were separated the first time . the parts hub housings are only alloy , be careful when handling that you don't ding the edges around the mating surfaces , it can cause them not to closley mate togeather again .
  15. The Following 2 Users Say Thank You to nipagu7 For This Useful Post:
    MB (1st September 2022), mihit (2nd September 2022)
  16. #59
    475 Post(s)
    Again ^^^what these Legends said
    Under duress in the bush old faithful Silasticy/gasket helpers can even out imperfections.
    Word of warning, be sure to carefully apply a thin layer carefully around and not globs of it over the stud holes. Studs themselves won’t thread all the way home if a glob accidentally finds its way onto the studs end, aint much tolerance for compression at the end of that little hole
  17. #60
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    the bonus with my method is that you have to empty a box of beer...
  18. The Following User Says Thank You to mihit For This Useful Post:
    MB (4th September 2022)
