Page 526 of 570 FirstFirst ... 524525526527528 ... LastLast
Results 5,251 to 5,260 of 5693
  1. #5251
    Plassy, I didn't know so rang Itech and they advise the 3000a designation is actually 3000CCA, however it is duty rated. So whilst a larger battery AGM/Wet Cell, even lithium has a CCA it also has a listed reserve capacity where it will deliver at some rating (probably assume the ability to supply some cranking capacity before either the internal cells get too hot or the current is depleted to the point of either being ineffective or unable to adequately crank.. The ITECH unit is 3000CCA, but the duty point is massively lower time wise, however it is alternately linked to the number of starts at that rated 3000CCA. I think the box states the unit can do 40 jump starts on up to an 8L diesel before requiring a recharge, however unsure if these are one after another of some other timeline. Anyway, its a monster
    I have a Nocco unit and rate it highly. I keep it in the back of the car permanently plugged into a Cig port. constant trickle charge while driving. I ahve pulled over and helped more that a couple of motorists. Works great.
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (18th January 2022), PeeBee (18th January 2022)
  3. #5252
    Didn't think about that. the 900amp unit i have in the subaru can sit there in the rear cig lighter - thanks for that Darren.
  4. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (18th January 2022), MudRunnerTD (18th January 2022)
  5. #5253
    What amperage is your Nocco mate? Mine also rides in the back on charge when driving but was useless as an ashtray on a bull when needed (600A peak output). What sort of vehicles have you zapped with it?
  6. #5254
    Yesterday now, honestly thought I’d wasted $75 USD downloading the complete series workshop/parts/maintenance manuals for our officially now vintage 3.0T breakout force drott/track loader beast
    Thanks to the puter file received it turns out after further investigations that a usual Aussie-Case backhoe runs the same torque converter sleuthing
    Found one ready in NSW ready for changeover and rolling again
  7. The Following 5 Users Say Thank You to MB For This Useful Post:
    PeeBee (18th January 2022), Plasnart (18th January 2022), Rossco (18th January 2022), rusty_nail (18th January 2022), Stropp (19th January 2022)
  8. #5255
    Bought a better heater today for the fuel line, all metal, banjo fittings and gaskets, 8mm barbs, FINALLY happy - I think!
    Model is DHS1208
  10. #5256
    Fantastic mate, that is great news!!!!
  11. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
  12. #5257
    Inhave a GB70. I used it to start Roofy's car in the back yard when we did the big clean up. It had not been run for a year and the radio didn't even work. I was a little worried but left it sit a minute then cranked it into life. To Mt surprise I immediately removed it like I have before ans the car shut down. I jumped it again and left it connected for 15 minutes while the Alternator caught up.
    It has jumped my GU TD a heap of times too. Jumped the GQ a few times too. As mentioned it is plugged in constantly in the back of the car so always fully charged. It's been great.
  13. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (18th January 2022), PeeBee (19th January 2022), Plasnart (19th January 2022)
  14. #5258
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Also have the Noco GB70 that's rated at 2000 amps. Haven't needed it yet for the Patrol but I do use it to start my old Kubota tractor occasionally rather than buy a new battery for it..
    My previous 400 amp Powertech, that I got as a gift, wouldn't start the tractor and also wouldn't start my wife's 2.2l TD Sorento.
    John
  15. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    MB (19th January 2022), Plasnart (19th January 2022)
  16. #5259
    Patrol God Stropp's Avatar
    38 Post(s)
    Ha, when I joined telecom in Perth 1977 we had a drott the same, good machine 💪
  17. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    MB (19th January 2022), MudRunnerTD (19th January 2022)
  18. #5260
    This is probably your old one Stropp, it’s a 1975 model and one of its ripper’s has been customised for cable laying to a depth of around telco 400mm 🪝
  19. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (19th January 2022), Stropp (19th January 2022)
