Page 999 of 1049 FirstFirst ... 499899949989997998999100010011009 ... LastLast
Results 9,981 to 9,990 of 10488
  1. #9981
    192 Post(s)
    So cool, just remember which lube is in which lol . .
  2. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (9th March 2021), Plasnart (9th March 2021)
    472 Post(s)
    Been thinking about swapping the sump bolt and brass washers for a trickle tap if I ever get bored on Friday nights
    Calder Park Thunderdome should burnout smoke some rice burners up properly in the old 70rwkw TD42T
  5. The Following 3 Users Say Thank You to MB For This Useful Post:
    Mickhead (10th March 2021), Plasnart (9th March 2021), Rossco (9th March 2021)
  6. #9983
    109 Post(s)
    What's going in the lefty @MB ? I'd be needing a sticker or some other method to remember what's where. Bloody great invention though mate.
  7. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (9th March 2021)
  8. #9984
    472 Post(s)
    10L of 80W-90 emergency gear oil Plassy Mate
    My memory is bad but my eyes can hopefully still just tell the difference
  9. #9985
    472 Post(s)
    Just worked out a future reminder Plassy Mate, all the Gurus swear by this methodology:
    “There’s no Pumpkin oil Left”
    “There’s no Sump oil Starboard right”
    Aaargh me Matey *
  10. The Following 4 Users Say Thank You to MB For This Useful Post:
    Cremulator (10th March 2021), Mickhead (10th March 2021), Plasnart (10th March 2021), rusty_nail (10th March 2021)
  11. #9986
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Mucked around sacrificing coolant to the coolant gods in the overflow vent, after replacing all cooling system caps, so blanking caps for radiator and 16 PSI pressure cap to expansion tank, and cycling through from warm to cool and refill and repeat over and over (for any air trap removal), as per fault finding instructions from Brunswick, and guess what, no changes, overflow tank still blowing out coolant and coolant does not get hotter than 60 degrees by the laser temp gun on the two tanks.
    So pressurization coming from somewhere right deptie being told it is unlikely to be a head gasket or a cracked head. So the discussions will continue.
    Evidently BD has identified a shop in Blackheath (in the blue mountains) that is happy to work on these 6.5 chevs. so looks like we will be dropping in there eventually.
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  12. The Following User Says Thank You to Truckus For This Useful Post:
    MB (10th March 2021)
  13. #9987
    Expert Mickhead's Avatar
    Oct 2019
    😂 or use your nose and go by the smell of the 80w 🤢
  14. The Following User Says Thank You to Mickhead For This Useful Post:
  15. #9988
    472 Post(s)
    Sent poor old Grandpa Spec GQ and his new little legal 2” spings a wee bit deeper than he appreciated
    Never underestimate throwing hard earned coin at good winches and or modification upgrades thanks @MudRunnerTD Legend
  16. The Following 9 Users Say Thank You to MB For This Useful Post:
    10G (21st March 2021), Cremulator (21st March 2021), Hodge (21st March 2021), mudnut (21st March 2021), MudRunnerTD (21st March 2021), PeeBee (21st March 2021), Plasnart (21st March 2021), Rossco (21st March 2021), rusty_nail (21st March 2021)
  17. #9989
    194 Post(s)
    Back on break, started the beast for a quick run, and was doing a cursory look over things under the bonnet and noticed a dull orange glow on a 12V - cable to the accessory fuse block. Quick finger check and receive a nice little 12V finger burn. Checked quickly with voltmeter and accessories running at 10.5V. Switched everything off and found the earth not was loose. Tightened up, back to 12.8, simple things can catch you, pays to do the checks.
  18. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (21st March 2021), MB (21st March 2021), Rossco (21st March 2021)
  19. #9990
    22 Post(s)
    Glowing as in the accessories weren't lighting up properly or the actual joint was glowing?
    96 GQ coil/Cab
    08 G6eT
