Another good water proofing improvement form factory is to seal up the clutch a bit better (assumimg its a manual). Worth siliconing around the fork boot both ends and also the little bung at the bottom of the bell housing. Can pull it out every service or so often to check theres no water that's got in or oil that might have come from rear main.
Thanks Rossco, I'll check that out as well.
