Page 971 of 1057 FirstFirst ... 969970971972973 ... LastLast
Results 9,701 to 9,710 of 10566
  1. #9701
    177 Post(s)
    Im trying to make sense of that.
    Yep, I'm scratching my head too
    Think he means swap wheels around 180 ...
    Kind of like tyre rotation.
    Rotate the wheel 180 degrees on the rim, which makes the heavy spot on the rim now the light. Which now requires less weights.
  3. #9703
    177 Post(s)
    Nuth'n worse than the dreaded death wobbles. .
    Couldn't agree more. It's farkin horrible ...
    I gave up trying to fix mine. Multiple tyre balances and rotations . Wheel bearings . Pretty much every bush up front got done ...
    Nowadays I just sit below the 90kmh death wobble sweet spot ...
    I'd rather others shake their hands at me for going slower, than my car shaking the hell out of me.
    177 Post(s)
    My head hurts.
  5. The Following 5 Users Say Thank You to Hodge For This Useful Post:
    Avo (25th November 2020), growler2058 (24th November 2020), mudski (24th November 2020), Plasnart (23rd November 2020), Rossco (24th November 2020)
  6. #9705
    Nice cheap fix mate
    $30 bloody dollars lol
    Wish I did that at the start!
  7. The Following User Says Thank You to AB For This Useful Post:
  8. #9706
    Expert Mickhead's Avatar
    Oct 2019
    Are you saying the rim is out of balance without the tyre on it?
  9. #9707
    Quote Originally Posted by Mickhead View Post
    What I believe Jaysee is trying to say is that if the tyre/wheel combo needs a lot of weight to balance the the tyre should be popped from its bead and reseated approx 180 degrees from where it started. This would then hopefully require a lot less weight to be applied to the tyre wheel combo. Unfortunately there are stuff all shops that really practice this anymore.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
    jay see (24th November 2020)
  11. #9708
    I believe you are correct mate. Thats exactly what I was trying to say.
    The last tyre place I went to, I asked if they would do that to reduce the amount of weights and they did.
  12. #9709
    Oct 2019
    Mate that suggests the rim is unbalanced too, that is not ideal!
  13. #9710
    Yeah I was thinking thats what he was trying to say today. But, it could also make balancing worse too. But yeah, how many shops would spend the time rotating a rim.
