Quote Originally Posted by Nazgul View Post
Yeah you blokes are dead right about the protection and ease of use. Having a look around I have found a cheap bar to fit up. I still want to do some experimentation with out the bar too.
I'm putting it on a diet and more or less removing unecessary things and then building it back up with minimum requirements. So weight savings where possible are always sought after.
Threedogs, spot-on those tie down points above the rear step aren't to be trusted. I've removed mine.
Sent from my SM-A520F using Tapatalk
for the sake of 5 kilo's, I would not be touching or modifying the towbar, you are basically being a 2nd manufacturer, and would need to get it tested and certified, in case something goes pear shaped - like your recovery
if you could modify it to be better and lighter but still as structurally as strong, dont you think the manufacturers would have already thought of that - to save money and increase profit?
unless you are getting a falcon tow bar and modifying it to fit a patrol - which would be stupid to say the least, there would be no sane reason to "cut it up for weight" you would be just compromising its structural integrity and making it dangerous
are you an Engineer?
can you certify the towbar once modified?
